![]() | Home > Maintenance & Modifications > 200 Tdi cyclone/crankcase breather hose part ERR 1729 sizes? |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
A search on here shows a question raised about the dimensions (internal and external and length) of this hose from the cyclone to the air filter but no definite answers.
This part costs between £40-£50 pus for a short moulded hose which seems a bit steep! Is it possible with the correct dimensions to make up your own with a vacuum hose say from Gates at £18 a metre, as the moulded hose will not be long enough because the PO had removed the oil bath air filter and replaced it with a KN type air filter fitted in the upright position. Jeff Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
