Home > Puma (Tdci) > Blown turbo replacement
steve E
Wales
Hi All
I’ve got a blown turbo on my 2.4 Defender.
Will this just need a new turbo or will the engine need a rebuild.
I’ve been advised that some metal particles from the turbo could be floating in the engine oil and a new engine would be the best solution.
Many Thanks
Steve
Post #948903 10th Apr 2022 5:55pm
Dinnu
Do you have big chunks of the compressor blades that are missing? Most likely they get stuck in the intercooler.
Worse case is that they get stuck on the valve seats and prevent the valves from seating properly. That would lead to low compression in the affected cylinders.
But they would not reach the oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #948905 10th Apr 2022 6:07pm
steve E
Wales
Thanks for the advise
I’m not sure on how much damage to the turbo there is but
I’m told that I can have an engine flush and a new turbo, but the best solution would be
a complete engine and clutch assembly.
Post #948906 10th Apr 2022 6:15pm
hank
Take the inlet hose off the turbo and inspect the compressor wheel for damage > 110 XS Double Cab
Post #948991 11th Apr 2022 11:32am
Caterham
....and a new clutch assembly
someone taking you for a ride?
I'd get a second opinion.
then go with the turbo only - wait and see if the engine is ok or not.
Post #948993 11th Apr 2022 11:37am
steve E
Wales
Thanks guys.
I’ll get a second opinion
Post #949607 16th Apr 2022 10:50pm
LR90XS2011
what they said, you need to see the turbo check how much metal has passed into and beyond the intercooler DEFENDER 90 TDCI XS,
Post #949612 17th Apr 2022 6:39am
