![]() | Home > Maintenance & Modifications > Provent 200 installation components |
Hi, What engine do you have?
For the TD5 you need
The circulation components: 19mm hose 3x 19mm to 19mm connectors 2x 25mm to 19mm reducer hoses 2 25mm jubilee clips 7x 19mm jubilee clips The oil drain hose: 10-12mm clear hose 1x Drain tap with barb fitting Image. Trace the breather hose around to the Provent which is mounted to the heater box. ![]() Click image to enlarge |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
Thanks Geobloke - helpful information and photo.
![]() I was hoping to try and fit it without any reducers (using the KAON 19mm adapters) and using only two pieces of new hose without connections if you get what I mean? Which drain tap did you use? Thanks, Will |
I can understand that, but I did n't have the choice at the time of sourcing the parts for the mod. As for the tap it is a simple ball valve tap you can get from BandQ or other hardware store.
When I bought a set of the KOAN adapters, I did it directly via eBay and it worked absolutely fine. However, I'd be tempted to buy the Provent 150 model instead as it's still man enough for the engine size but doesn't require adapters at all. It's also slightly cheaper
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4317 ![]() ![]() ![]() |
LandRoverAnorak. Have you fitted a 150? If so, do you have any pictures, or guidance as I would like to do the same. From everything I can see the standard commonly available 150 has the intake port flush on the mounting face with no barb for a hose. I think you can special order a different configuration from Mann, but nowhere seems to stock it. I think this is the the reason the 200 is the default choice even though it’s oversize for the job. 2007 110 TDCi Station Wagon XS
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
I bought my adaptors direct from Oz, with no problems whatsoever.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
There are some photos of my provent 100 in my progress thread and also here. No adapters required https://www.defender2.net/forum/topic82634.html > 110 XS Double Cab
