Home > Maintenance & Modifications > Concern with metal shavings when tapping axle breather hole?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Ive ordered up the Gwyn Lewis axle breather kit which requires tapping the stock puma axle breather holes as they are not threaded. I have also picked up the magnetic diff plugs they offer.
My question is- should I be concerned that in the tapping process metal shavings are going to get in the axle housing and cause trouble? I have little experience tapping so want to be sure I get it right and not cause damage.
Post #948685 8th Apr 2022 7:54pm
LR90XS2011
put some grease on the tap and only go a few turns at a time before removing it and cleaning the swarf of, repeat until done. DEFENDER 90 TDCI XS,
Post #948686 8th Apr 2022 8:02pm
big110
brilliant. appreciate that advice mate! new territory for me learn something new every day.
assume with the grease I wont need any cutting oil!
Post #948687 8th Apr 2022 8:04pm
geobloke
As above the grease trick works a treat. Nice thick grease no cutting oil required Thumbs Up
If you are at all concerned tap the hole, clean the hole with brake cleaner, let it all settle, drain the axle oil and refill. Belts and braces but it will limit the swarf even further. Thumbs Up
Post #948749 9th Apr 2022 9:05am
Screbble
Sound advice Thumbs Up
Just out of curiosity - what sort of thickness is the axle casting?
Post #948752 9th Apr 2022 9:27am
big110
Ahh. And with the Gwyn Lewis mag drain plug I should be safe!
Post #948783 9th Apr 2022 2:59pm
geobloke
Perfectly safe, yes Thumbs Up
Post #948784 9th Apr 2022 3:03pm
big110
Thanks so much
Post #948786 9th Apr 2022 3:07pm
