Home > Technical > No power to reverse lamp- assume reverse switch needed?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
I’ve got no reverse lamp at the moment. Tried new bulb to no avail.
Assume safe to move on to replace the reverse switch? Was hard to tell from the fuse panel under dash what fuse may be for it but they all looked good.
2014 2.2 puma. I do have a reverse switch here as a spare just for this reason
Post #947146 26th Mar 2022 10:10pm
Screbble
I’ve never had that problem myself but have read many threads on here that suggests it’s reasonably common. Some good guidance on here on how to get at the pesky switch Thumbs Up
Post #947165 27th Mar 2022 8:57am
Mo Murphy
Check the pins in the connector to the back of the lamp, they can rust to nothing.
50 Shades of Pennine Grey
Post #947191 27th Mar 2022 3:30pm
spudfan
Ireland
The fuse is clearly marked on the pull down flap. Mine is a 2.4 so I do not know whether your fuse is in the same place as mine but the hand book has a page with the fuses and their locations. Iwould physically remove the fuse and replace it to see if that was at fault.
I had an issue with my reverse light and here is how it was finally sorted.
https://www.defender2.net/forum/topic81961.html 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #947751 1st Apr 2022 8:13pm
