Home > Puma (Tdci) > speed limit |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
the speed limiter is set whilst doing the PDI, you could invalidate your warranty if you get it removed. 2.4 90 XS
20th Sep 2011 11:46am |
lvcity Member Since: 20 Sep 2011 Location: beijing Posts: 3 |
thanks! you mean remove my warranty? how can i do it? |
20th Sep 2011 11:55am |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
A "friend of mine" has a speed unlimiter box that sits between the tacho and the "brains" and can be disconnected almost invisibly.
The "brains" are told the vehicle is within speed but the tacho reads the higher speed correctly. Nobody is any the wiser. It really is an awesome bit of kit... but also an awesome price: almost 700 Euros (from www.matzker.de) However, "my friend" says it's worth every cent, even without other tuning Cheers, Matt Last edited by ZeDefender on 20th Sep 2011 11:57am. Edited 1 time in total |
thanks, i'l check that out! |
20th Sep 2011 11:57am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2591 |
Why would you want to go faster than this in a Defender? If you want to go fast, get a sports car -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
20th Sep 2011 12:39pm |
absolutely NOT!!! Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
20th Sep 2011 2:31pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3140 |
If you invalidate your warranty you would have no comeback with the dealer or Landrover in the event of any malfunction of the vehicle, they will just say you removed the speed limiter so you no longer have any warranty. It is also probably not a very good idea to exceed the limit set anyway, as the vehicle was hardly built for high speed performance. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
20th Sep 2011 4:33pm |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
I dont think they could argue that because you went fast your warranty no longer counts.
Same as if you modify the car with new tyres, rack, spots, bumpers, ladder etc etc There would have to be a provable direct link between the speed and the failure. Pom |
20th Sep 2011 4:36pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Something that I was pondering over in one of my frequent moments of boredom...
The rev limiter is sat at about 4500rpm, in top gear at 60mph it's doing 2000rpm, so... 60mph - 2000rpm 90mph - 3000rpm 120mph - 4000rpm 135mph - 4500rpm Would the gearbox/diffs/whatever actually be able to handle that sort of speed? I know I wouldn't want to attempt that sort of speed in a Defender anyway! |
20th Sep 2011 6:48pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
no. aerodynamics being the main issue. drive drain wouldnt take it either.
20th Sep 2011 7:00pm |
Without a remap, which resets the speed limit to whatever the tuner deems appropriate the only other option is to change the speed setting in the instrument cluster at PDI. The only option which removes the speed limiter is the Saudi Arabia overspeed function which is set at PDI and you shouldn't be able to change that. There is an option to set the limiter at either 82mph or 87mph with certain diagnostic tools. My limiter was removed with the remap though I rarely go faster than 80mph as I'm conscious of the strain on the drivetrain and the consequences of a blowout at high speed.
20th Sep 2011 8:12pm |
As an alternative, I can assure you "my friend" has a box from Matzker which takes the signal from the tacho and tells the system it isn't going faster than e.g. 130 kph. The tacho reads the real speed normally but the system is told something else. No remap, no trace in diagnostics. "My friend's" defender (without tuning) goes smoothly up to 150+ kph, most importantly without that "constipated" feeling you usually get at the limited speed. The box can be removed, e.g. for servicing, and the wiring (5 discrete wires and a small connector) can be tucked up behind the instrument cluster. Believe me, it's brilliant, especially on German motorways where suddenly finding your speed "stop" can be a problem. p.s. I (er... I mean "my friend") also rarely go much above 145 kph but (he) hates being "constipated"... |
20th Sep 2011 9:54pm |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Why would you want to do 90mph plus in a defender?
25 mpg is bad enough are you trying to hit single digits? |
20th Sep 2011 10:14pm |
Only in emergencies Actually, the consumption cruising at 145/150 isn't that bad - I drove to Italy and got over 20 mpg... |
20th Sep 2011 10:24pm |
