![]() | Home > Technical > Defender Puma High Level Brake Light Not Working. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
That’s a good result
![]() Glad you found the break - must have been a hairline fracture. I’m sure your post will be helpful to others ![]() It’s great when you can repair things yourself. |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
Thanks Scribble. Frustrating it went wrong during the MOT but at least it was the only thing! 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
This is a common occurance. I simply ran two wires inside the rubber window seal from the bottom connections to the top connections. The rubber can be just prised aside as you push in the wire (one each side). 1982 88" 2.25 diesel
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 394 ![]() ![]() ![]() |
I had the same trouble on my Td5, I did as Spudfan did and ran a cable up the inside of the window rubber. It all tested up fine, 12 v being delivered to the bulb holder but as soon as any load was applied the volts dropped to zero. I put i down to the metallic strip bonded to the window and due to an impending MOT I did the cable fix.
This was done as a "temporary fix" about six or seven years ago and it is still in place! Before that I noticed it was not working when we were out somewhere and I used silver foil from a chocolate bar to get continuity in the element at the top! That lasted until I got around to doing the wire fix!!! 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Spudfan and Penfold. Feeding in a wire was an option but I was keen to keep it almost original 😊👍 2009 Defender 90 CSW 2.4 TDCI.
