![]() | Home > Maintenance & Modifications > Water Leak Problem solving |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
I’m assuming you have seen a copy of the water ingress manual, unfortunately it’s a weighty tome .
But just in case https://www.landroverweb.com/Pdf-files/Man...Manual.pdf |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
Although it is a bit of a hassle to do, removing the headlining will often reveal witness marks if water has been getting in above the cantrail level. If there are not witness marks, an assistant with a hose can often reveal the leak.
It is possible to get large amounts of condensation on the inside of the room under some atmospheric conditions, but from your description it sounds more likely to be a leak. |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673 ![]() ![]() ![]() |
This might help
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 196 ![]() ![]() ![]() |
Great thanks all, looks like I have some reading to do!
That interior shot looks like a worse version of what I have. will go around the roof and have a closer look, and I need to get head lining out soon anyway as I need to fit a work light and rear camera |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
Might also be worth looking at the external joint/seam where the ‘vertical’ part of the roof meets the gutter. I found a hairline crack that I ‘treated’ using Captain Tolley’s.
