Home > Puma (Tdci) > just bought this one.... no bonnet stolen....
dgardel
Italy
In black
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #89775 18th Sep 2011 2:07pm
T1G UP
how do they work?
Post #89776 18th Sep 2011 2:35pm
pom
looks a bit 'diy' as well.
Pom
Post #89777 18th Sep 2011 2:51pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Pom
Defenders are DIY,so the part at home.I think it's fine once painted. Puma 110 SW
90 V8 SOFT TOP
Post #89781 18th Sep 2011 4:06pm
Sockpuppet
Reading the website I think they are used as a extra fixing and don't in themselves stop the lifting of the bonnet.
I suppose they'd be good if you could fix a big rubber bumper on the top with a security fixing to stop it going vertical.
Post #89785 18th Sep 2011 4:53pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Whats to stop somebody coming along with a 6mm allen key and a 13mm spanner and undoing the bolt?
Post #89840 18th Sep 2011 7:26pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Use shear nuts..
However, even that could probably be defeated by getting the bonnet vertical and pulling until the hinge pin pops out of the section on the bulkhead.
What we need is something bolted to the bulkhead (with security fixings) that blocks the open section of the outer hinge (the bit that the bonnet hinge lifts out of).
In addition to this, the use of shear nuts on the bonnet hinge plate itself should make removing the bonnet almost impossible without lots of time or special tools.
Post #89859 18th Sep 2011 8:17pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i've been thinking about bolting a steel cable under the bonnet at the back edge somewhere [even rivit it to a rib] and then to the bulkhead so you can still open the bonnet fully. if you know laptop security it would be a bit like the kensington locks.
it won't stop the determined thief but it should stop the opportunist thief!
thoughts? BM52
Post #89866 18th Sep 2011 8:50pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
thoughts?
Working on something similar for mine right now.. Just waiting for the box of bits to be delivered... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #89894 18th Sep 2011 10:47pm
