Home > Technical > Defender 90 (300 Tdi) Trailer Warning light??
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Hi folk
Bought a trailer back from Lincolnshire yesterday. The trailer, a Brian James Cargo Shifter had a 13 Pin plug fitted while my Beast has two 7 pin sockets. I fitted a 13 > 7 Pin adapter and all trailer lights functioned correctly. I should add my Defender90 is LED lit and the trailer was normal bulb.
What I didn't have was the green "Trailer" Warning light illuminated on the dash.
First thought is the bulb, but rather than taking the dash apart at this stage ... are there a pair of contacts I can short together to test the bulb circuit OR is there another way?
... and is there anything else I should check or be aware of??
MTIA (Still learning Whistle )
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #943955 26th Feb 2022 8:34pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Hi John,
With the trailer cable disconnected the trailer indicator light should come on when you first put on the indicators. It should only flash once with the left / right indicator warning light and then extinguish.
Try disconnecting the trailer cable and putting on your indicators. If it doesn't work then the bulb may have blown.
Hope this helps.
Andy
Post #943965 26th Feb 2022 9:45pm
Cubflyer
Hope this helps.
Andy
Hi Andy, thanks for that - much appreciated Thumbs Up
Just done the above but sadly nothing so I'll check the bulb tomorrow.
ATB
Post #943967 26th Feb 2022 9:56pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
When the Led indicators were fitted was the relay changed? The Led one may need tuning to work correctly with trailer connected. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #943975 26th Feb 2022 11:53pm
This. Your LED indicators don't provide enough load to activate the trailer light. Either fit an adjustable flasher relay and tune as Ramsay suggests or fit load resistors to the indicators (or go back to bulbs). Darren
Post #943986 27th Feb 2022 9:44am
Cubflyer
Hi Ramsey - thanks for your reply. Yes relay was changed and I recollect there was an adjuster knob on the top. 2010 Defender 90 300Tdi CW (White/1994)
Post #944016 27th Feb 2022 4:59pm
Cubflyer
Hi Darren ... Thanks for your input too, will check it out later Wink
Post #944017 27th Feb 2022 5:01pm
Cubflyer
Well yet again the wealth of knowledge on this Forum shines throught ...
A BIG thank you to all who replied Thumbs Up
Bulb tested OK so attached my trailer light board and then went to the LED light relay.
Turned the adjustment knob about a quarter turn and the "Trailer light" illuminated - Job done Exclamation
Many thanks again
Post #944025 27th Feb 2022 5:53pm
