Home > Technical > CAN Bus speed on PUMA 2.2
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I'd like to build an auxillary display in the rev counter, using an Arduino and OLED. However my knowledge of CAN bus is a bit limited at the moment.
So far I believe the PUMA 2.2 uses an 11 bit protocol but I'm not sure what speed the CAN bus is.
Anyone happen to know or where I can find out?
Failing that it's gong to be trial and error with the different standard rates.
Post #943807 25th Feb 2022 5:43pm
macfrank
Car Scanner app's profiles says 500k, 11 bit
Post #943838 25th Feb 2022 9:28pm
macfrank
p.s. here's some code for the 2.4
https://github.com/posmanet/DeCANder
I was looking for the guy's posts in the german blacklandy forum but couldn't find them anymore. The forum has recently had a software update... Confused
Post #943840 25th Feb 2022 9:43pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
quite unfortunate what has happened over there Sad Roaming around 🇳🇴🇨🇭
Post #943841 25th Feb 2022 9:49pm
steveww
Really useful thanks.
I'll keep you updated with the build and publish everything on GitHub.
Post #943876 26th Feb 2022 11:23am
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
500k
Post #945325 10th Mar 2022 6:00pm
