Home > Td5 > Do i remap after EGR blnk and decat/mid remove?
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Hi all,
I've blanked the EGR and plan to remove the cat from the down pipe, and the centre silencer.
Do i get the engine remapped once the above work is done or do i wait until 6 months time when i can afford an allisport intercooler for it?
Who would you recommend do the remap if you were located in Gloucestershire?
Thanks in advance
Post #942919 18th Feb 2022 10:04am
geobloke
Yes remap after doing your performance mods, otherwise you will have to remap twice.
As for remapers near you... Not sure I am afraid. Maybe Allisport can help as they are not far up the road from you.
Post #942928 18th Feb 2022 11:08am
bankz5152
Always best to wait until all mods are done before mapping.
Egrblank/downpipe wont make a huge difference to mapping but the intercooler will.
Get in touch with Empire Tuning,
Post #943056 19th Feb 2022 5:25pm
kenzle8a
Are there any options that let you keep the egr? Our farm truck could do with some more oomph, however some of the places we go do have vosa check points so I’m committed to keeping it legal.
Post #943082 19th Feb 2022 7:22pm
phillips321
What have VOSA got to do with checking the EGR?
Post #943085 19th Feb 2022 7:29pm
bankz5152
Tampering with emmisions...
Yeah, can be mapped with or without EGR. Again speak to Empire Tuning, he will map your car to what you want with your mods.
Post #943086 19th Feb 2022 7:56pm
kenzle8a
Emissions check points are common at some of the agri events we go to, they check to see if there’s stuff removed like egrs or de cats, the inspectors aren’t stupid.
Post #943087 19th Feb 2022 7:58pm
phillips321
Well that’s worrying! What’s the repercussions if they find I’ve removed the EGR? I’ve not long had the vehicle so potential wasn’t me that done it 🤷‍♂️
Post #943088 19th Feb 2022 8:04pm
kenzle8a
A pretty impressive fine as ours is a commercial as part of the farm, it’s a far bigger fine than civilian ones i think.
Post #943090 19th Feb 2022 8:25pm
I would look at Alive tuning, ATRIC device which you can do from home yourself. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #943108 19th Feb 2022 11:26pm
On a td5 it's easy to disable the EGR without removing it. I don't think that even VOSA can check whether it works, just whether it's present.
The td5 EGR does restrict the intake slightly so removing it completely has minor performance advantages, but simply disabling it provides the bulk of the benefits and prolongs the life of the engine.
Post #943121 20th Feb 2022 9:20am
Procta
it wouldn't make any difference if remove those before or after a remap.
A Decat will let the system breath better, I did this my 306 HDI, all that did was let the turbo spool up quicker, and the engine rev better. EGR stuff, i never noticed a difference in performance, But that was due to the system working, but if its knackered, and you remove it. you will notice a difference. my 300 Tdi was really down on power for some reason, and it turned out to be a damaged EGR pipe. Binned the full smash off, and it was a totally difference motor. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #943141 20th Feb 2022 11:55am
