Home > Td5 > Exhaust downpipe to turbo flange nuts...
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Hi guys,
Got a new exhaust for my 2005 TD5 but for the life of me i cant loosen the flange nuts holding the downpipe on to the turbo.
I've been spraying PB Blaster on for the course of a week now, and also tried loosening when warm.
Does anyone have any tips on making this possible without snapping the studs?
Thanks in advance.
Post #942674 16th Feb 2022 9:49am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I used my impact wrench with succes. There is always a chance that it snap but I find that with an impact wrench you have more luck getting them loose then with brute force. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #942717 16th Feb 2022 5:02pm
phillips321
How did you managed to actually fit the impact gun in there? For the life of me I can get it in there.... unless you used a very long extension and go from underneath?
Post #942719 16th Feb 2022 5:08pm
Procta
from my experience with my 300TDi, i had to double up on extensions just to get the length, I used a breaker on mine, but i think someone had already been there before. As the manifold and inlet was loose. Shocked
My dad bought a two impact guns, on battery and the other electric, i even bought another one for the larger 3/4 sockets. These have been pure gold on rattling off bolts, rather than having a go with a breaker. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #942775 17th Feb 2022 2:34am
Harry.O
I've always found it easier from underneath with a few extension bars, you can then use a breaker bar or impact gun if needed. You may want a UJ or a wobble end to get there but it's easy to do. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #942798 17th Feb 2022 10:51am
landy andy
Get them bloody hot with a long run, then a spanner on them.
Post #942882 17th Feb 2022 9:18pm
roel
Yes some long extensions. Roel
Post #942990 18th Feb 2022 7:46pm
lightning
Have you tried this?
Post #942993 18th Feb 2022 8:14pm
landy andy
Yes. Too many times.
Post #943005 18th Feb 2022 9:11pm
roel
I hate working on hot equipment. Roel
Post #943482 22nd Feb 2022 7:37pm
Screbble
Did you get this sorted?
Like others ^^^ I use 2 or 3 long extension bars and a standard ratchet from underneath.
The first time I did it, I actually filled plastic domed nut covers with releasing oil and left them on the turbo/downpipe flange nuts for a week…
It appeared to work.
I always replace with new copper locking nuts and plenty of copper grease (which probably burns off) but the second time it was a doddle.
Sadly I’ve had a few downpipe changes over the years.
Post #943959 26th Feb 2022 8:59pm
Screbble
PS I didn’t drive it with the plastic nut cover s on!!!!
Post #943960 26th Feb 2022 9:00pm
