Home > Technical > Front wheel position
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Hi folks,
Could someone advise the position of the front wheel in the wheel arch. I'm trying to look at pics online but it's pretty hard to judge. How does mine look compared to everyone's else's. I've 35" tyres, I can fit 3 fingers in at the back of the wheel. Is this the same as everyone or should it be more centred
Shane
Post #942196 12th Feb 2022 5:24pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
How far your tyres sits to the back depend on the lift you have. These are also 35" but I modified the wheelarces a little to be able to drive off-road.
I have about 7 cm suspension lift. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #942218 12th Feb 2022 7:04pm
shanecl
Thanks for the pic Roel, looks awesome truck
I've standard springs in mine Shocked Shocked
Post #942449 14th Feb 2022 1:56pm
Hufflepuff
Slightly off topic I appreciate, but I'm keen to know which 35" tyre sizes are you both using, and what rim offset to be able to fit under the standard arches (albeit with a little snip on Roel's edges)? 2005 Td5 90 XS
1989 V8 110 CSW
Post #942471 14th Feb 2022 4:39pm
camelman
I have approx 95mm clearance on mine.
Thats with a 50mm lift however and +50mm arches on ET-32 Wheels.
Tyres are 315/75/16 BFG KM3
I'd think wheels with less offset would start to limit steering lock.
@roel - are yours 10.5 or 12.5 width?
Post #942474 14th Feb 2022 4:53pm
shanecl
I'm running a different setup then normal. Gold star if you guess 🤣🤣
Reason I asked I wanted to see what it's meant to be on a normal defedner
Post #942578 15th Feb 2022 4:37pm
shanecl
Thanks Camelman, looks like your centre cap is running in line with the centre of the wheel arch. I may have to do some correction on mine Embarassed
Post #942579 15th Feb 2022 4:38pm
Hufflepuff
Oh, Toyota axles? OK that explains that Smile 2005 Td5 90 XS
1989 V8 110 CSW
Post #942590 15th Feb 2022 5:02pm
shanecl
Sorry Disco 2 axles
Post #942591 15th Feb 2022 5:09pm
Hufflepuff
Oh well, I guessed wrong Very Happy 2005 Td5 90 XS
1989 V8 110 CSW
Post #942605 15th Feb 2022 5:48pm
roel
These are 35 x 10,5 x R16. The rims are 8J ET 0 I believe. This all is a bit wide for the standard arches but still have a good turning circle. Roel
Post #942625 15th Feb 2022 8:17pm
Hufflepuff
Thanks Roel. So potentially ET10 would make them a bit more 'legal' in the UK where the tread must be within the bodywork, although this would likely depend also then on what tyres you were running. 2005 Td5 90 XS
1989 V8 110 CSW
Post #942651 15th Feb 2022 11:01pm
shanecl
We'll give a silver star for effort Very Happy Very Happy Laughing Laughing
Post #942690 16th Feb 2022 1:18pm
roel
A quick measurement: The outside off the widest block on the tread sticks 20 mm out and the widest part off the tire about 35 mm.
This is probably also not completely legal in The Netherlands as the tire is allowed stick out 30 mm and the track width may only be increased by 2%. But it looks like they only stop tuned cars for that. Very Happy Roel
Post #942721 16th Feb 2022 5:22pm
