![]() | Home > Maintenance & Modifications > rear alarm door switch wiring |
The door switches only have one wire - an earth. Basically, they make contact with earth when released and break when pushed in. I don't know what wiring you've got but all you should need to do is tee into the earth wire to the nearest light. Darren
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727 ![]() ![]() ![]() |
You're looking for a single black female spade connector on a purple with blue stripe wire for the switch.
This wire will come down from the roof - perhaps it's been pulled up and tucked away? Do you have central locking (doesn't appear so)? But if you the purple/blue for the door switch should follow the orange and pink central locking wires down from the roof. The green and purple is a brake light feed, and the black is earth - neither of these will help you for the door switch! ![]() ![]() |
GrouseII Member Since: 29 Dec 2017 Location: Bucks Posts: 37 ![]() ![]() ![]() |
Thanks gentlemen.
its all dark arts but from what you both say an earth cable (purple with black spade) from my interior light (hidden under the head lining currently dangling in fresh air, connected to the spade connector on the new switch will magically make the light come on and set the alarm off when the door opened? I've got a car mate who hopefully can explain the theory too me an other day but got to say it bewilders me that there is no power to the switch but there you go. Much appreciated Grouseii |
The purple with blue stripe wire is the only wire which connects to the door switch.
When the door is opened the switch electrically connects the purple/blue to the body via the switch mounting screw. The body is at 'earth' - connected to the battery negative. This switching to earth is detected by the alarm ECU (yes you have one) which brings on the interior light/triggers the alarm. Martin ![]() ![]() |
Ah, got it.
I had the naïve idea that aluminium body was not a conductor but google tells me it is. What a numpty! Thanks again |
Just in case it helps anyone in the future with this issue here is a link with a good wiring diagram showing what's going on (lets hope they don't delete it!)
https://forums.lr4x4.com/topic/36884-interior-light/ ![]() |
