Home > Technical > Fixed Brake Pipe - what is the connector size (imperial)
Grenadier
Evening all. I’ve just received some very sexy looking cupro nickel brake pipes for the DC. Problem is that I popped down there today to get the old set out and realised that my 11mm spanner is a shade too large. They’re fixed tight and I desperately want to avoid burring them, so need to get my hands on the correct imperial spanner. In France. Does anyone know what size it is, or what size imperial spanner relates to being just under 11mm? Obviously I might just buy a set as I assume there is a host of other imperial bolts around the vehicle. With that in mind, anyone recommend a good set that I might be able to get through Amazon. If not, and if I ruin them or can’t get them off, I may have to replace the master cylinder as well.
Thanks in advance as always. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #940554 1st Feb 2022 7:29pm
htb2
Wales
7/16" af spanner will do nicely.
Post #940556 1st Feb 2022 7:41pm
ickle
only ones I can find on Amazon.fr:
https://www.amazon.fr/BGS-polygonales-ouvertes-pièces-1782/dp/B003DDSAH6/ref=sr_1_82?__mk_fr_FR=ÅMÅŽÕÑ&crid=1XBKO21LMWM3E&keywords=Kit+de+clés%2C+conduite+de+frein&qid=1643741102&sprefix=kit+de+clés%2C+conduite+de+frein%2Caps%2C80&sr=8-82
But surprised they're not metric, I'll look at mine tomorrow after the weekly Leclerc trip.
HTH Keith
Post #940558 1st Feb 2022 7:48pm
Ianh
7/16 at 11.11mm is bigger than 11mm, a 13/32 is 10.3188mm so may fit.
Better to get a 11mm flare spanner as that grips more faces on the nut, and a quality one , say Halfords advanced, may be a tighter fit as your 11mm may be just slightly oversized.
Alternatively get a 10 mm and hand file it wider, does not take much effort, or put the 11mm in the freezer overnight, wear gloves, the see if it has shrunk sufficiently to be a tight fit.
Post #940570 1st Feb 2022 8:20pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi Grenadier. The problems never end. Search for a 10mm 11mm brake pipe spanner. Better quality for a better fit!
Post #940576 1st Feb 2022 9:03pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Defo use the above wrenches, have seen a slightly rounded 11mm be actually removed with one of the above Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #940578 1st Feb 2022 9:24pm
Grenadier
Right. Bought a set. Metric. It’s been freezing here, so maybe the extra play was that the bolts had shrunk and the spanner, out of a warm car, was ‘normal’. Also it occurred to me that I have no intention of keeping them, so could just use some punchy pliers. Thanks all. The spanners will no doubt prove useful for other occasion as well. Monsieur Le Grenadier
Post #940599 2nd Feb 2022 7:48am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
If the brake pipe coming off will not be replaced, cut the pipe and use a socket to remove it. I think that us what most mechanics would try to do as you are far more likely to get it to move with a good fitting socket.
I have just had to remove the caliper on my defender, which was interesting. This was for a wheel bearing (though I had decided to replace the calipers).
Removing the other half and the bolts was even more interesting. And so begins my vehicle maintenance journey!@
Post #940613 2nd Feb 2022 9:54am
