Home > For Sale & Wanted > [Wanted] A good R380 or Puma seat box
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I hope to move the seats inboard by an inch on my 127 to create a bit more shoulder room. To enable this I'm looking for a 300tdi / Td5 seatbox with the earlier captive nut plates or a late Puma one so I can modify it to suit. I've looked at YRMs offerings but can't quite justify that sort of expense.
Ideally the seatbox will be corrosion free and nice and straight. Rolling with laughter I don't need the battery/toolboxes and am happy to arrange a courier if needs be.
Thanks in advance. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #940385 31st Jan 2022 7:58pm
Oldowner
Puma seat box is exactly the same as the R380 seatbox and is likely to be in better condition. They are also better to modify as they did away with the m8 rivnuts for the seat mounting and instead have reinforced steel mounting rails riveted to the underside of the seatbox to which the seat bolts to.
Post #940432 31st Jan 2022 9:56pm
Shroppy
Well you learn something new everyday! I have what I thought was a puma one here but it has M8 rivnuts so perhaps it's td5 after all. Will amend the ad, thank you. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #940434 31st Jan 2022 10:03pm
