Home > Td5 > Really sluggish acceleration
Page 3 of 4 <1234>
Jordan
United Kingdom 2000 Defender 90 Td5 HT Stornoway Grey
Thanks, just tried the 4th gear 25mph test, starts to pick up around 35-40mph
Post #944026 27th Feb 2022 6:00pm
Dinnu
Jordan wrote:
Just taken off the turbo intake pipe, engine of stone cold, turbo is free to turn but does not run freely. I am used to massive blowers on ships engines which once spun will continue for ages, this just stops as soon as I stop turning it.
That is normal. A good turbo should not have any axial play (no play when you pull/push). But it will have a bit or radial play (up/down/sideway movement). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944029 27th Feb 2022 6:11pm
Jordan
Ordered myself a Nanocom, so I can see what is happening. I did find the Waste gate actuator rod was set at 15 threads, so altered that by a couple, feel it boosting now lower down, but still pants on the top end.
I also noted on my run out last weekend, which was 80miles round trip I used over half a tank of fuel. Shocked
Post #944387 2nd Mar 2022 8:50pm
lightning
Look on the bright side, at least if it gets stolen the rozzers will be able to catch it
Post #944476 3rd Mar 2022 5:14pm
Jordan
Yeah and on foot Laughing
Post #944477 3rd Mar 2022 5:15pm
Jordan
Bought myself a Nanocom unit.
Anyone on here no what readings I should be getting and when, so I can have some references.
Post #944907 7th Mar 2022 12:41pm
Jordan
Just been for a run.
I have the following fault codes up
4.3 coolant temperature circuit Logged high
6.3 coolant temperature circuit, current
10.1 Air Conditioning Fan Drive open load
10.3 Tachometer Drive Open Load, current
10.4 Gearbox/ ABS open Load, logged
10.5 Air conditioning Clutch Drive , logged
14.1 Air Conditioning Fan Drive Open, current
14.3 Tachometer drive open load, current
14.4 Gearbox/ ABS drive Open load, current
14.5 Air Conditioning Clutch Drive, current
24.7 Problems detected with Auto gearbox, current
The coolant level is full, I bled it off last week, it never gets above the halfway mark, nanocom gave me a high of 88 while out.
It does not have air conditioning or ABS or Automatic Gearbox.
While out driving in 4th gear I can get max 3600 rpm and that give me 0.9bar of boost.
Post #944923 7th Mar 2022 2:51pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Has it had a new ECU salvaged from a Disco one wonders?
Might be time to talk to someone who understands Td5 ECUs?
Post #944943 7th Mar 2022 5:26pm
lightning
All the air conditioning, tachometer and ABS faults can be ignored as these are likely not fitted to your Defender unless it's the XS version (half leather seats)
The auto gearbox is a bit odd and could mean you've got the wrong ECU
Post #944950 7th Mar 2022 6:08pm
MadTom
Focus on fault 6.3, it looks like, it has no valid engine temperature values. Look for live data and compare temperature values with "reality" of engine. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #944952 7th Mar 2022 6:11pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If you have the original ECU you should have a sticker with your vin-number on it.
Does your temperature gauge shows normal temperature as I believe an ECU programmed for a disco won't work correctly with a Defender temp gauge. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #944966 7th Mar 2022 9:17pm
MadTom
Disco ECU in Defender results in wrong working temperature gauge (needle is going in opposite way), but only the gauge, not ECU, because temperature sensor is the same. Much worse is bad habbit of gas pedal, it works like a "switch", on road it is ussable, but off road it is wery hard to controll engine power.
WIN is also written in the ECU software, but it is only for evidence and only in newer NNN type ECUs. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #944998 8th Mar 2022 7:02am
lightning
lt's got to be something like that, he's tried everything else!
When the ECU failed in my 110 the garage fitted a Disco one to get it moving and it did run, but there was no power and the gas pedal didn't work properly, as described above.
Post #945009 8th Mar 2022 9:23am
Jordan
Temperature gauge does up to just under half when in use. The Nanocom gave me a digital display of 88degrees yesterday.
I will check the ECU today.
Post #945010 8th Mar 2022 9:34am
Jordan
Just checked the ECU, all plugs are clean, there is a sticker (not LR) stating the chassis number, using the Nanocom it rear the VIN of it and it corresponds to my log book.
Post #945025 8th Mar 2022 10:39am
Page 3 of 4 <1234>
