Home > Puma (Tdci) > Anyone had an ABS module fail?
mcma1
Trying to diagnose a brake issue at the minute. After a short drive the rears are binding up and we are thinking it may be the ABS module. Going to plug it in and see if any faults come up but asking here in case anyone has had one fail and what issues if caused?
Thanks Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #939209 24th Jan 2022 2:21pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Had one fail on a Suzuki swift, caused brake binding and strange braking. Dismantled it and looks like it rusted from inside out, guess previous owners had never changed the fluid, as that was like coffee when extracted. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #939212 24th Jan 2022 2:38pm
mcma1
Need to check over a few things before I commit to replacing as it’s an expensive part. Not had any issues for the past 12 months so something has definitely failed somewhere. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #939226 24th Jan 2022 3:59pm
Race.it
Maybe a crushed pipe? I very much doubt your car has not had the fluid changed often.
Some abs units on the e46 bmw I know can be taken apart as the computes on them fail and you can swap the bodies. Maybe another option if it’s defiantly the module that’s gone. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #939227 24th Jan 2022 4:08pm
mcma1
I have had a steering angle error for a while now which I know upsets the ABS but we had it re calibrated today and then went for a pretty lively drive and no sign of the issue. Not sure if that was the cause so will have to wait and see. They did bind up on the way over to the guy with the LR software and we just let the pressure off at the master cyclinder so maybe something has corrected itself. Confused Andy
2014 Corris 110 SW
LS3 V8 build...
Post #939290 24th Jan 2022 9:48pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
I recently replaced front pads. Or at least tried to. It turned out the piston were sized and there was a lot of corrosion on the calliper shoulder where the pads Sat. I removed the callipers. Used a deemed multi tools to clean the corrosion. Emery cloth to clean the rust. A G-Clamp to pull the pistons back in - fitted the old pads to pump the pistons out, g-clamp wind back in and freed them off (used brake fluid to lubricate). After several hours work, all refitted, new pads, greased up with brake grease, bled the system through - all worked a treat.
So, my guess, if there was and ABS fault you would normally get an error light on the dash. I would suggest to strip and check the rear callipers perhaps with new pads.
Post #939293 24th Jan 2022 10:06pm
mcma1
Checked all the pads etc. The entire front and rear brakes were changed during the engine swap and are all still like new. With the steering angle out the ABS module puts a TC error light up after 30mph. We tested the ABS out this evening on a damp back road and all working as normal with no warning lights now after the re calibration. Could well just be luck that they haven't bound up since but at least it rules this out if it does happen again. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #939299 24th Jan 2022 10:17pm
matchap801
Nightmare. What about the Mongoose IDS SDD - system driven diagnostic - cable (clones sold on a famous auction site) older versions of the software worked without the internet link? Someone on here may have one? Never tried one but it may be able to run functional tests?
Post #939317 24th Jan 2022 11:24pm
