![]() | Home > Off Topic > Ethernet/Network switch - which one? |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1067 ![]() ![]() ![]() |
Another thought - why a switch rather than a simpler hub?
Can you even get a hub now? Switches are so cheap it’s pointless.
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Consumer grade switches are much of a muchness but:
1) check if you prefer ports on the front or back of the unit 2) if you need jumbo frames check it is supported ( but most decent brands support it) I take it you are only looking for gigabit speed - This has ports on rear, but lights on front so you can see of tx/rx https://www.amazon.co.uk/8-Port-Desktop-Gi...M&th=1 This has ports on rear https://www.amazon.co.uk/D-Link-DGS-108-Gi...4&th=1 Both have metal case |
All that stuff you worry about with analogue hifi connections and gold cables is out the window, its all digital so there is no degredation of signal/quality etc, and corrupt data will be resent; so long as everything is properly terminated and routed (i.e. not running with power cables, not bent like a pretzel).
The purpose of having a faceplate on the wall is to protect the cable in the wall, and those 'structured' cables should really be solid core rather than stranded which is more flexible and used in patch cables. All that being said the various standards for all this stuff are pretty forgiving especially in a home situation so you can take major liberties before you even see a problem with the device. |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
So have I. Its silent, cool, reliable - its only drawback these days is that its 'only' 1GB, I would really like them to bring out a 2.5GB version. 2005 Td5 90 XS 1989 V8 110 CSW |
