Home > Td5 > New chassis incoming - what housekeeping should be done?
plumpmoose
Got 21 years out of the current one, but needed patching for MOT. Car is my pampered pooch so Marsland ordered.
While body off what should I do? I want to keep car standard, so worn bits mainly.
Main brake line replaced last year - but the other ones could be done?
New clutch is on the list.
Thanks in advance.
Post #938461 20th Jan 2022 11:07am
Dinnu
Fuel pump is one of the hardest to reach once the body is back on, at least on a 90. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938471 20th Jan 2022 12:05pm
jimbo55
When I did mine I decided to do pretty much everything whilst the body was off and where applicable I put galvanised items on.
From what I remember I did:
New bushes all round, new brake lines all round, new fuel pump, new fuel filter header, new tank breathers (old ones were damaged), galv rear rub support, seat belt mounting brackets, galv cranked radius arms, galv a frame arms, even the little things like exhaust bushes, etc. probably did a few other things but can’t remember as it’s been a couple of years now
As much as you try to plan everything, when you strip it apart then you will find other things which are damaged, worn our or just in need of replacement.
Post #938472 20th Jan 2022 12:17pm
