![]() | Home > Puma (Tdci) > Engine sound 2008 Puma |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
Evening all, came back from a trip out and halfway home heard this lovely sound, any ideas? No warning light, oils fine, water fine, cannot see any leaks or fractured pipes etc.
Regards Paul https://www.defender2.net/gallery/albums/u...18FC4E.MOV Cogito ergo sum |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Check the injectors are tight, and not leaking.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Does sound injector related.
Remove the black plastic injector cover (2 bolts at the front) You will see four injectors (blue below) held in place by two clamps (green below), each one clamping a pair of injectors. Give each injector and clamp a wiggle to check the clamps are tight and adequately retaining the injectors ![]() |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167 ![]() ![]() ![]() |
This is much like the sound that mine made when the retaining bolt shown in Hank's picture failed on the school run. The sound was caused by a tiny amount of movement of the high pressure pipe/injector. I made a bid for the dealership 6 miles away and got halfway there before the pair of injectors came completely adrift and we coasted gently to an unpowered stop.
My daughter remembers it as the day when the Landy made even more embarrassing noises than usual outside the school gate. |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101 ![]() ![]() ![]() |
you can see injector 3 bouncing in your vid. easy enough fix with a new set of copper washers and stretch bolts. you might as well change all washers while you're there.
Only get the audio when I download it
Thanks for all the replies everyone, took the cover off today and injectors 3/4 were bouncing around like billyho, I’m taking it in on Monday for a diagnostic check and will mention it then, appreciate all the replies, thanks once again.
Regards Paul Cogito ergo sum |
Did you tighten down the bolt? I wouldn't drive it as is > 110 XS Double Cab
as hanks says. driving it with them loose will not do the head any good.
Just give the clamp a nip up (not too much. think the spec is only 7Nm and 180degrees) |
Even if you just “nip” them up before driving. I wouldn’t recommend driving it with them loose.
Okay guys, cheers for the info
Just a quick update, couldn’t tighten them up as away from home and no tools, drove it very slowly to the garage, it was the injectors, tightened up, full diagnostic, running sweet, thanks again for all the help, much appreciated
Glad it was a nice simple job.
