Home > Td5 > Half shaft to flange connection
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
2005 TD5 110
Can someone let me know if anyone has tried the <£100 kits on eBay and if they’re any good. I don’t need anything serious heavy duty.
Here’s my current issue:
Here’s and example of the kit is tempted to get, will it fit and will they last? https://www.ebay.co.uk/itm/LANDROVER-DEFEN...1763507420
Thanks in advance.
Post #938242 18th Jan 2022 10:25pm
geobloke
Yes I have that very kit on Miffy. It is now four years old and doing just fine. Covered approx. 20-30k miles and no clunks.
Post #938245 18th Jan 2022 10:31pm
landy andy
Most on here are fitting one piece shafts instead of the two part in your link. If you want the cheapest option you will probably find that the play you are showing in your vid is just worn drive flanges, not the shafts as they are a harder metal than the flanges.
Post #938246 18th Jan 2022 10:33pm
kenzle8a
I fitted the brit part one pice one’s and they are pretty decent IMO
Post #938250 18th Jan 2022 10:56pm
phillips321
Can you link me to the Brit part one piece ones please? I’m struggling to identify the ones I need.
Post #938252 18th Jan 2022 11:01pm
LR90XS2011
assuming your picture is the rear just get some series 1 discovery rear shafts, these are 1 piece and fit perfectly, I have had some for several years in mine with no issues, I dont off road but lots of old Discos do without issue mine cost £10. DEFENDER 90 TDCI XS,
Post #938266 19th Jan 2022 7:34am
It's worth noting that Discovery half shafts are the same as those used on 90's but are thinner than those used on 110's. The difference will be to accommodate the weight of the vehicle (and hence the loads transmitted through the drivetrain) rather than the usage. I know that some folks use them on 110's but I personally wouldn't risk it.
Despite the completely warranted scepticism about using Britpart stuff, their one piece half shafts seem to get good reviews, or rather there aren't lots of failure reports. Darren
Post #938268 19th Jan 2022 7:54am
phillips321
Can you link me to the correct one piece Brit part ones please. It’s a mine field.
Post #938271 19th Jan 2022 8:47am
lightning
l fitted Britpart driveshafts and drive members to my 110. So far they've done over 80,000 miles and are still okay.
l've greased the splined connection a couple of times, not sure if it should be greased or left dry but as l said, they've done over 80,000 miles so it can't be doing any harm.
Post #938272 19th Jan 2022 9:02am
A quick search gave this as the first result, although their may be cheaper suppliers. It gives the part numbers for a wider search, though:
https://www.ebay.co.uk/itm/LANDROVER-DEFEN...3.l4275.c1 Darren
Post #938276 19th Jan 2022 9:27am
kenzle8a
These are the exact ones I ordered for my 2002 TD5 110 and I've run them for about a year now with no issues (they have a bit of surface rust but I forgot to paint the ends before I fitted them, will sort it when its a bit warmer).
Left
https://www.island-4x4.co.uk/halfshaft-rea...37448.html
Right
https://www.island-4x4.co.uk/halfshaft-rea...37447.html
Post #938281 19th Jan 2022 10:08am
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Or these
Post #938282 19th Jan 2022 10:09am
landy andy
Got mine from Luke (LOF). Top chap and service Thumbs Up Thumbs Up
Post #938285 19th Jan 2022 10:12am
stew 46
Very impressed with there extreme clutch bundle , one piece input shaft and half shafts now all fitted Bow down it’s transformed my defender Very Happy Very Happy
🥟 stew
Post #938286 19th Jan 2022 10:16am
phillips321
stew 46 wrote:
Or these
These look good. How do i know if i've got a Rover rear axle?
Fits Defender 90 AND (110/130 ONLY ONES FITTED WITH A REAR ROVER AXLE)
Post #938300 19th Jan 2022 11:55am
