Home > Td5 > power steering pump
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
power steering pump
Close to turning the 200,000km mark on my 110 and the power steering pump is leaking and in need of replacement.
Several options out there, from an expensive Genuine one, to lower priced Bearmach, Britpart, Allmakes etc.
Any recommendations / experience as the preferred replacement? Don't mind spending on the Genuine if it's a superior part, but if any of the less expensive ones are comparable quality, I would prefer to save my money to spend in other places. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #938220 18th Jan 2022 7:59pm
geobloke
I confess I went for a Britpart item and it has and continues to do what it is meant to do without leaking Rolling Eyes The quality was good and IIRC it was made in the UK as well Shocked
Bearing in mind that the PAS pump also drives the water pump it might be worth buying a replacement one of those as well. For what they cost, you'd kick yourself if you got in there and noticed a weeping seal. Plus it is a great time to do a full engine flush and coolant refresh ready for those hot Vancouver summers Thumbs Up
Oh and a spare drive belt for your stocks too.
Post #938222 18th Jan 2022 8:31pm
miker
I bought an OEM one from flatdog in september 2017, ~30k miles ago. It's doing it's job just fine!
OEM POWER STEERING PUMP QVB101350G ( x1 @ £124.38 each) £124.38
Post #938256 19th Jan 2022 12:25am
cocker
Just done mine went for a reconditioned one on an exchange basis
genuine and good value
Post #938274 19th Jan 2022 9:15am
Fatboy Slim
Wales
Ebay seller rr_steering does a seal and gasket kit for the original Hobourn pump. About the £25 mark. Done a few now and they work great. Had loads of issues with aftermarket pumps, zero issues with rebuilt originals Thumbs Up
Post #944837 6th Mar 2022 7:11pm
Fatboy Slim
Wales
Post #944838 6th Mar 2022 7:16pm
rallysteve
Before committing to replace/refurbish. Have a check for any backlash between the PAS pump and water pump. I found the drive coupling between the two had worn down substantially on mine (waterpump shown but PAS pump was almost the same:
Post #944852 6th Mar 2022 8:32pm
