![]() | Home > Puma (Tdci) > screeching in one of the rear wheel |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Hi there!
From some time ago I had a screeching in the left rear wheel (like the typical wear brake pad one) when I turn the car all left. Some idea about what can be? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Thanks Konabikes11,
That was my first thougth (and I hope that will be the issue), but the screech appears only when I turn left ![]() ![]() Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Very same on mine. Brake pads in just one side. I have done everything to the pads: slots, cuts, etc. Next step is to swap pads from between tyres or skim the disc a bit. Puma 110" SW
try 'Copperslip' on the back of the pads 2.4 90 XS
Had the same problem a couple of weeks ago on Salisbury Plain - stone trapped between the disc and stone guard.
Guards are easy to remove so might be worth a quick check. Bob |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
So annoying especially when you can't free it very easily and you have to drive past people
Fast reversing with sudden stop most-times dislodges stones.
