Home > Maintenance & Modifications > Vented Brake Discs/Rotors for non ABS Puma
Grenadier
Ok,
I know this is a constant subject of debate, but just wondering where we are at on Sun 16 Jan 2023.
What is the general consensus for the best replacement for a standard 110 Puma, non ABS vented front brake set up. By standard I mean NON BBK. I’ll be doing the following:
New copper brake pipes
Goodrich braided lines
Caliper deep clean
SS piston and seal replacement
New fluid
New Mintex pads
Etc etc
So what discs/rotors are we favouring these days?
Solid vented? Mintex, Delphi?
Slotted/dimpled vented? Which brand? Britpart, Bearmach, Brembo, EBC?
Terrafirma Wavy slotted/dimpled vented? If so, why?
Or do I just buy a LOF kit? Which seems to come with a lot of stuff I’m not sure I need?
Any thoughts appreciated Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #937905 16th Jan 2022 9:15am
Bluest
I refurbed my existing vented set up. I used Delphi discs, Ferodo pads, AP callipers and Pioneer flexi hoses and it’s been spot on, no squeaks or or other problems.
In the past I have used Pagid products (Euro Car Parts) with unsatisfactory results so I avaoid those now. 2007 110 TDCi Station Wagon XS
Post #937908 16th Jan 2022 9:43am
kenzle8a
I did my 110 with the LOF kit, made life so much easier. On reflection I would have gone with the Power Spec kit over the road spec.
Post #937909 16th Jan 2022 10:22am
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
I did my 110 Puma (with ABS, vented front) using LOF POWERspec pads & discs (+ bearings)
Calipers (blast cleaned and painted) were overhauled using Zeus Eng. SS Pistons + SS bleed nipples
all the flexi hoses were made up by Pioneer 4X4 direct from hard metal line to the calipers and the long lines that run acoss the rear axle
Can recomend Zeus, Pioneer and LOF - Thumbs Up
The guy who did the calipers, not so Shocked (the work and finish was great, the return packcing and complaint service Rolling with laughter ) Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #937915 16th Jan 2022 11:45am
Smyles_
Denmark
EBC slotted discs with yellow stuff pads was a very noticeable upgrade for me on the 110 over the stock combo. The yellow stuff pads don't work when cold as they are a street/race compound, so you need to put some heat in them when you set off. However, I never once experienced brake fade like I was previously with the stock setup - I regularly hooned on quiet back roads Twisted Evil
I would highly suggest braided brake lines though if you go a "performance" route. Whenever I dug deep with the brake pedal I could feel the stock lines expanding, was incredibly spoungy feeling and unpleasant.
These are my thoughts as of January 16th. I have the same setup on my 130 except now with green stuff pads, but it's not finished yet... Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #937916 16th Jan 2022 11:54am
kenzle8a
Couldn’t pay me to ever use EBC pads in any car, i had a set of green stuff explode in my calipers a few years ago in my other car. Useless when cold, not great when hot IMO.
Post #937918 16th Jan 2022 12:53pm
