Home > Technical > Question for those who've had bonnets / doors stolen
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Hi guys, if you've had a bonnet or door stolen, could you tell me whether it was on a newer vehicle (surely it must have been as older doors would be a royal pain to remove without tools?) and whether they were able to unscrew them, or did they drill them out? In the words of baldrick, I have a cunning plan me lord, dependant on your answers. Very Happy Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #88685 12th Sep 2011 1:52pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Bonnets usually on post 2007.
Doors and every thing else on any age truck if they look ok.
They take all the bits by unbolting them, except the obvious lift off approach with the bonnet.
Post #88695 12th Sep 2011 2:56pm
funrover
Thanks Paul, I figured these would be targeted as body panels are likely to be better and bolts will probably remove easier, anyone else had them stolen on an older vehicle? Editor of FunRover - One blog. Read it!
Post #88704 12th Sep 2011 4:39pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Bonnets post 07, because of the "Power Bulge" are wanted and easily removed normally by Lift approach. This could be foiled simply by the fitting of some form of " Bumper Stop" that prevents the said item being opened to the vertical position i.e.: something " tasteful" that is fitted to the windscreen edge of the bonnet and fouls up against the windscreen surround preventing the bonnet going vertical. Then the ***** would have to undo the bolts which could be changed for security fittings.
A bicycle chain can be used BUT look how many bikes are nicked whilst chained up. These people come prepared so you have to do something unexpected to stop them. Twisted Evil LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #89195 15th Sep 2011 8:56am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Fit a fully welded rollcage. Whistle Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #89638 17th Sep 2011 6:23pm
noworries4x4
57 plate Puma Defender bonnet stolen from a Premier Inn car park in Birmingham last December propper pro job my solution is on here just check out my postings If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #89848 18th Sep 2011 7:52pm
