Home > Maintenance & Modifications > Hub Nut Size
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
Hub Nut Size
Hi all hoping someone is able to advise, need a socket for the hub nut on my Defender 2010 can anyone advise the actual size required measured the nut and it is 52.3mm but struggling to find.
Thought I would ask the people that know !
thanks
Post #934526 21st Dec 2021 1:07pm
Mo Murphy
52mm
50 Shades of Pennine Grey
Post #934527 21st Dec 2021 1:09pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
As Mo rightly says it's 52mm, you can get deep sockets or a box spanner from the usual outlets. A your machine is later model I'd suggest a socket because that nut should be tightened to 210Nm which is more than I'd subject a box spanner to.
As you have to stake the nut over when torqued up it's also good practice to replace the nut each time as well. Part number for the nut is RDF100000
MM
Post #934540 21st Dec 2021 2:39pm
MattyEssex
Thanks both, found a 2" socket that did the job but on hold now until replacement parts arrive which had now included the nut, bearing and seal.
thanks for the hlep
Post #934546 21st Dec 2021 3:16pm
Penfold_6290
I might be trying to teach you to suck eggs but if you're replacing the bearing you will also need to set the end float on the bearing with this type of hub, which differs from the earlier type hub which have 2 lock nuts. There's a good video on Youtube on how to do it, you will need the correct spacer between the bearings, there's 7 of the little Censored , each one 0.1mm thicker than it's mate. Trouble is, you won't really know which one you'll need until you have assembled it with the thickest 15.5mm spacer first. Not a problem if you have a supplier nearby, not ideal if you live in the sticks like me.
I ended buying all of them, I'm bound to need them at some time or another and the kit isn't daft money - LR2437 (it's 6 spacers, they don't supply the thinnest 14.9mm one)
Post #934548 21st Dec 2021 3:26pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Or scrap the spacer and revert to the twin nut system . No end float measurements and DTi gauges required !
Plenty of info on how to do it on here and I promise you’ll wonder why they bothered with the spacer .
In fact, why did they ?! https://www.instagram.com/hustynminepark/
Post #934628 22nd Dec 2021 8:57am
