Home > Maintenance & Modifications > Door Hinges
Guinness
Door Hinges
Hi All, I am after a set of door hinges as my doors are starting to sag quite dramatically. There have been many forum posts about these fancy security ones, but unfortunately, my budget is a constraint. Are aftermarket ones like these any good? :
https://www.lrparts.net/da1070w-full-front...shims.html
OR
Are OEM ones just that much better that I should fork out the extra money; (over 4 x the cost of after market)
Post #934226 19th Dec 2021 1:23pm
Dinnu
My opinion is that door hinges are not critical items, so I would give aftermarket a try. Maybe they rust, maybe they wear as fast... or maybe they last as long or more than genuine. Never replaced a hinge, although I have a set which I drilled the pin out and replaced the pin. No wear 20 years later, maybe cause they were on passenger side! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #934228 19th Dec 2021 1:41pm
geobloke
I went through the same decision process as you. Fell on a set of galvanised OEM hinges which I drilled for grease and painted with rattle can paint. Worked a treat and three years on they are still in A1 condition.
You can see the process from here https://www.defender2.net/forum/topic53859...;start=135
Post #934233 19th Dec 2021 2:21pm
Guinness
Currently I am swaying towards trying some well reviewed aftermarket ones, and if they fail in a year or so, then so be it, but i suppose its worth a try, i do like your idea geobloke of modifying the hinges to allow grease points!
Post #934268 19th Dec 2021 6:17pm
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
I replaced my hinges with Bearmach ones they were about £25 and about £18 for a rattle can of the correct paint 3 years later and all is good. that original ones lasted 16 years so will see how long these last lol
Post #934401 20th Dec 2021 5:32pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Second for bearmach ones!
Post #934405 20th Dec 2021 5:46pm
geobloke
You what they say... Every little helps and when it comes to Defender door hinges then being able to lubricate them can only be a good thing.
I have just been back through my orders and these were Britpart hinges. Apart from a small bit of spikey galv they were well made and took paint well. Cannot complain... Thumbs Up
Post #934645 22nd Dec 2021 11:39am
