Home > Puma (Tdci) > Charge battery through 13 pin trailer socket
Page 2 of 2 <12
90 Dreamer
Bearing in mind that everything is isolated battery / charging wise I can't understand how it can be any different corrosion wise??
Post #932246 2nd Dec 2021 9:50pm
90 Dreamer
discomog wrote:
I connect my charger through pin 9 (12v+) and pin 13 (earth)
All tested and sorted this evening and can confirm pin9 for Pos+ and pin13 for the battery earth......
Post #932248 2nd Dec 2021 9:52pm
It's the earth return on the towing electrics (I haven't checked the standard wiring so this was just my initial thought) which means the current path would be via chassis/body parts. Of note is that the corrosion seems to exist only on the side of the vehicle where the battery resides.
My concern is whether plugging a charger into the towing electric socket is accelerating galvanic reactions by fuelling/turbocharging the process.
If this was the case then it would seem better to either connect a charger direct to the battery terminals, or run a separate earth return cable from the towing socket direct to the battery (or maybe the main battery earthing point.
Utimately, on a vehicle so prone to the issue, it might be worthwhile to run cables to earth busbars around the vehicle and so remove the chassis/bodywork from all circuits.
Post #932266 3rd Dec 2021 7:49am
discomog wrote:
Through the 13 pin socket via pin 9 and pin 13
I'd be interested to know how yours is looking and how long it's been fitted.
Mine's been connected like this for maybe 5+ years (I'll have to check my records to see when I bought the connector), the first 3 out in the open, the last two under a carport. So conditions have been wet/moist, again ideal conditions for galvanic corrosion to thrive in.
Post #932268 3rd Dec 2021 7:59am
discomog
Supacat. My 90 is a 2015 model and is garaged and has had a Ctek charger fitted through the 13 pin socket from day one. I've replaced many of the original nuts, bolts and washers with stainless and therefore might expect it to be more susceptible to galvanic corrosion. I had a good look around the vehicle yesterday and found no evidence of corrosion like you are experiencing. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #932275 3rd Dec 2021 9:33am
Thumbs Up
Checking my records the trailer socket connector has been on mine since April 2013 - so a little longer than I had originaly thought - 8 years and 8 months!
Nearside rear passenger seat belt mounting:
Nearside rear passenger floor:
Nearside tub supports:
Post #932281 3rd Dec 2021 10:19am
Page 2 of 2 <12
