![]() | Home > Maintenance & Modifications > Replacing the rear Diff seal |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
its and easy job and assuming the drive flange has no rust or wear just a seal should be enough to complete the job.
It is recommended however that you replace the prop shaft bolts and nuts and the drive flange retaining nut. Word of caution scotch the wheels as the hand brake becomes inoperative when you remove the prop shaft bolts and you may also want to put it in diff lock before you remove the prop so the hand brake works through the front wheels. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 471 ![]() ![]() |
Hi,
Many thanks. Is this correct re parts you mention above?: Prop Shaft Bolts - Bolt 3/8UNF - LR045409 - Genuine Prop Shaft Nuts - Locknut - NY606042 - Genuine Drive Flange retaining Nut - FS112306P |
Certainly look like the right parts, forgot it was a bolt not a nut on the drive flange Doh!! DEFENDER 90 TDCI XS,
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 232 ![]() ![]() ![]() |
You can clean the area where the seal sits on the flange shaft with some fine wet/dry paper if it shows signs of corrosion.
Awesome, thanks all, much appreciated.
Cheers ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
It is also possible to use a "Speedi Sleeve" to repair the flange, although if it has deteriorated to the point of making this necessary a new flange is probably a better bet.
Be careful with replacement flanges though. I had a problem some time back with a non-genuine (but not Britpart) aftermarket flange supplied by an extremely reputable supplier which continued to leak after I had fitted it with a new seal. Upon investigation I could that the machined land for the seal was out-of-round by several thousands of an inch, which prevented the seal from sealing. This was completely invisible to the naked eye, it looked perfect. The extremely reputable dealer supplied a genuine LR flange free of charge as a replacement (which solved the problem). The dilemma as usual comes from the fact that a genuine flange is about ten times the price of a typical, supposedly-reasonable, aftermarket flange, and it is very hard to bring yourself to buy a part at such an absurd price. |
Hi Blackwolf,
Thanks for the advice. Hopefully it will be OK, but if not I will take your advice and bite the bullet to go genuine ![]() My list of 'things to do' is getting longer!! Thanks again. |
