Home > Technical > 2011 Defender Horn Failure |
fuse 27 under dash fuse box
7th Nov 2021 4:26pm |
https://1drv.ms/u/s!AtZSoWFHDgnGlkisYCA8iDgYfVxD?e=IjJwqe
look under alarm then you open the file it will ask how do you wont to open pick PDF two missing fuse from wire diagram think martin Click image to enlarge Click image to enlarge |
7th Nov 2021 4:31pm |
Donald.e Member Since: 03 Aug 2021 Location: Evanton Posts: 27 |
Cheers, the alarm sounder is good, but will check all this out
7th Nov 2021 4:58pm |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1026 |
Check the wiring behind the O/S headlight , mine had chaffed through
8th Nov 2021 10:33am |
alarm sounder and horn on same page of the wire diagram |
8th Nov 2021 10:52am |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 120 |
Had exactly the same problem, thought it was my grandson yanking on the stalk that broke it but turned out both horns had failed, think one failed a while ago, didn’t realise there were two, replaced and all ok, access by removing the headlights and pots, I tried removing them first and tweaking the grey adjustment screw, they worked fine for a few days then had to do it all again to replace them
8th Nov 2021 3:39pm |
