![]() | Home > Maintenance & Modifications > 3” lift and wide arches |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3400 ![]() ![]() |
Ive got terrafirma +50mm arches but you have to get them painted as they look too plasticcy otherwise.
Also running the standard HD utility springs with glyn lewis 50mm spacers on the springs. Get no rubbing. ![]() Click image to enlarge ![]() |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 403 ![]() ![]() |
Before you go up to a 3” lift, it is probably worth measuring your lift at the moment, looks quite low for a 2” lift with 35’s (was looking at your tyre comparison post the other day) so May have had the springs sag over time. If you can get away with retaining only a 2” lift then it will drive a lot nicer than when you go bigger 👍
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 377 ![]() ![]() ![]() |
Just when I think I've managed to suppress silly thoughts of huge tyres, external cage, winches, lightbars (and other things that my use of my defender really doesn't jusitify). Camelman posts another picture of his stunning example. It looks fantastic. ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5917 ![]() ![]() |
If you want to do your suspension properly, talk to Gwyn Lewis. And as mentioned there is 3” lifts, and there are real 3” lifts.
Silver110 Member Since: 10 Jun 2020 Location: East Sussex Posts: 49 ![]() ![]() ![]() |
Looks lovely, are you running spacers? I currently have 30mm bulldog spacers on. Also just looked at the terrarfirma wheel arches and says they cannot be painted? ![]() Click image to enlarge |
The arches painted fine?? Been on for 3 years now with no issue. Got them done professionally at the local body shop, cost £120 for the set to match them to body.
No spacers on, the wheels are Challenger ET-32 16x10. ![]() |
