Home > Puma (Tdci) > 2.2 TDCI sluggish after head gasket replacement
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
We took the time to get the proper head gasket, timing tools, and other necessary gaskets to do this job correctly.
We started with an overheat issue, we tested the coolant for co2, and it came back negative. We reloaded the stock map, and it still was over heating. We swapped the TC from 1.1 to 1.211, still problem at speed. We changed the thermostat, still. So I decided to do a head gasket swap.
Upon disassembly, we noticed the the timing wasn't spot on, but didn't pay too much attention to it at the time. We removed everything and found no fault in the original head gasket.
We installed the new head gasket with new bolts. As they are stretch to yield.
We blocked off both sides of the EGR cooler and installed the non DPF exhaust.
We attached all the accessories and primed the engine with new motor oil.
We then filled with coolant and started the engine to go through the initial heat cycle.
No leaks were found.
We did two full heat cycles, and cool downs and no faults were found. took the vehicle for a short test drive, and the engine light turned on. We reset the code and the one that always comes on is the turbo boost performance. We checked all the hoses and they are tight. We checked the bolts on the intake manifold and they are all tight. We checked everything we could and the engine performance is sluggish at best. Mash the throttle in neutral and it eventually gets to 2000rpm and then slowly creeps to 3000rpm. There is a slight puff of white smoke.
Level ground, its very slow, and no pep at all. Once load is put on the vehicle like a slight uphill the engine light comes on and its the same turbo boost performance code.
What did we miss?
My nanocom is unable to do a pilot correction nor write the codes for the inj...I am told its suppose to be a 16 character code, but all I find on the top of the inj are 11 or 13 or 6 digits.
Stealership is not an option, its something silly i am missing... Can't leave well enough alone
Post #922075 20th Sep 2021 1:02pm
Ianh
I thought you had to do an ECU remap if deleting an egr and DPF on a 2.2 puma. So this may well be your issue.
https://bellautoservices.co.uk/store/puma-...-road-use/
Worth giving them a call re this as they can do remote maps as well.
Post #922081 20th Sep 2021 1:19pm
Naf
That was already done by Alive for the customer...
That is why we completely blocked off the egr cooler and removed the dpf canister. Can't leave well enough alone
Post #922083 20th Sep 2021 1:24pm
Naf
Tomorrow I am goin to remove the turbo inlet and pressurize the system to 10psi and soap up all the air lines and intake to find the air leak through bubbles...
I used the old Inj seals, it couldn't be those could it? Can't leave well enough alone
Post #922093 20th Sep 2021 2:22pm
Naf
Found a hose clamp that was loose.
We pressurized the system to 1bar and listened for leaks. one was found before the intercooler. We are now buttoning up the ride for a trial
Was something simple, but the engine bay is so cramped its a chore to look around. Can't leave well enough alone
Post #922168 21st Sep 2021 8:44am
hank
That's a great idea. What is the internal diameter of the boost hoses? Wouldn't mind doing this myself > 110 XS Double Cab
Post #922177 21st Sep 2021 9:24am
Naf
We removed the turbo inlet hose and attached an old inner tube there with the quick disconnect fitting and held it in place with a hose clamp.
Its not rocket science, but it helps to keep it simple.
Latest results are in, we still have an issue, we will try the same technique but this time turn the ign on but leave the engine off.
I feel it could be an EGR leak.
I am out of options, and covid has a lot of my friends shops closed. Can't leave well enough alone
Post #922191 21st Sep 2021 10:35am
Naf
56mm of or 52mm id on the turbo inlet.
All the boost hoses are 51mm id. Can't leave well enough alone
Post #922208 21st Sep 2021 1:30pm
Naf
P2263-21 Turbocharger/Supercharger Boost System Performance- Signal amplitude < minimum
Possible Causes: Intake system blocked/leaking Manifold absolute pressure and temperature sensor fault Variable geometry turbine vane actuator fault Turbocharger failure
Action: Check the intake system for blockages/leaks, check for manifold absolute pressure and temperature sensor related DTCs and perform the relevant corrective actions Check the variable geometry turbine vane actuator linkage. Check the turbocharger bearing and oil seal. Install a new turbocharger as necessary.
Cut and pasted the above from B.A.S. website.
We checked for leaks this time with the ign switch on, no leaks were found.
I highly doubt its a turbo issue. Its in great condition and the actuator linkage moves freely. Can't leave well enough alone
Post #922213 21st Sep 2021 2:00pm
hank
I'm sure I read the actuator wiring can wear through. Have you checked here? > 110 XS Double Cab
Post #922220 21st Sep 2021 2:27pm
Ianh
People often forget about the Air Charge Sensor” part number LR032216 on a 2.2 puma as I’m sure the 2.4 does not have one
That’s what LR call it but in reality I think it’s an Air Charge Temperature Sensor.
Listed as part 8 on this diagram https://www.lrworkshop.com/diagrams/land-r...es_2.2tdci
Perhaps checking that’s connected, clean and working is worth while
Post #922271 21st Sep 2021 8:14pm
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
Just a "stupid" suggestion.
I don't suppose you or someone else stuffed a rag in an opening in the inlet system and it has been left in there?
Just thinking out the box?? Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #922337 22nd Sep 2021 12:48pm
Co1
Have seen that done more than once Nige, so not a stupid question!
Post #922395 22nd Sep 2021 6:47pm
dgardel
Italy
I was thinking the same thing.......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #922467 23rd Sep 2021 2:23pm
hank
Possible Causes:
Action:
Cut and pasted the above from B.A.S. website. > 110 XS Double Cab
Post #922472 23rd Sep 2021 3:00pm
