Home > In Car Electronics > Permanently Connected Compressor
Dagonet
United Kingdom 2009 Defender 90 Puma 2.2 HT Java Black
Hi Folks,
I'd Like to have my compressor connected all the time rather than have to open up the battery compartment and connect the crocodile clips every time. What would be the best way to do that? This is my compressor: https://www.ebay.co.uk/itm/202981346559
Voltage: DC 12 Volt
Amperage: 45 Amps
Power: 540w
My reasoning is that I'll be more inclined to air down if I don't have to faff to air back up.
Any help appreciated.
Post #921865 17th Sep 2021 10:50pm
Dinnu
I would put a fuse, a normally open relay and a switch on the dash to switch on the relay (and hence the compressor).
Do you need help with the circuit? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921877 18th Sep 2021 7:28am
DSC-off
I've seen a great way to ease the air up process.
The guy had made up lengths of flexible air line in a circuit, a H arrangement. There were clip on valve connectors at the 4 ends, to fit on all 4 wheels.
The compressor connected at one point in the circuit, near to an adjustable pressure valve.
To air up at the end of the trail, he connected the compressor to the circuit, clipped it onto all 4 wheels, switched it on.
Then got out his coffee and sandwiches, and had a chat while his tyres were all blown up to the same preset pressure! Cool
We were very impressed by this, not having to connect the compressor to each wheel.
He'd been using the method for a long time and reported no issues.This was in the USA, where airing up and down is much more common. Doing it every day for a week could become a real pain. Depending on the road miles between trails, some just left it at the lower pressure all week.
Post #921884 18th Sep 2021 9:05am
Dagonet
Thanks for the advice Dinnu. Your description is so clear I don’t need a diagram! Very much appreciated.
Post #921886 18th Sep 2021 9:17am
Dagonet
Very fancy, I’m not at that level yet!
Post #921888 18th Sep 2021 9:18am
I've seen that sort of system before but it always strikes me as a bit odd, as tyre pressures are usually different, front and rear. Darren
Post #921889 18th Sep 2021 9:24am
DSC-off
Easy to get round that.
Put a valve in the system to shut off the front half. Then continue to raise the rear pressure.
The main use was to quickly get from 16 psi to 30 psi for 30 or 40 miles blast down the highway. At the end of the week it would be prudent to check the condition of each tyre and set the pressure accurately before setting off for a 1000mile journey home.
Post #921891 18th Sep 2021 9:30am
I appreciate that it can be done. I'm just not sure that it is. I'm also not sure that it's significantly quicker than doing each tyre separately. Unless the compressor has a huge reservoir, it's output will remain the same but just split over four tyres. I admit that it looks cool though, and like the idea of a plumbed in airline. Darren
Post #921892 18th Sep 2021 9:37am
DSC-off
It was no quicker to do all 4 together, just less trouble. Have a break, and leave it to it.
Post #921893 18th Sep 2021 9:41am
Dinnu
I missed an even simpler connection, by for example using an Anderson connector, example fitted outside of the seatbox, and replace the crocodile clips with the Anderson counterpart. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921894 18th Sep 2021 9:51am
Dagonet
This seems like the best option, and the least work!
Post #921896 18th Sep 2021 10:21am
Dinnu
I did something similar (but not an Anderson) but to connect a battery maintainer for when I am not using it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921902 18th Sep 2021 10:57am
