Home > Td5 > Rear spring replacement
excossack
1999 TD5 110 SW (no rear side facing seats)
235/85 R16 ATs
I am due for new rear shocks, which will be standard LR ones so was thinking I might as well replace springs which have been on since 2015 and where new take off when purchased.
Current springs are Purple/Brown (RKB101111)
110 carries a draw of recovery gear (shackles/strops/pulley blocks) etc all the time.
When doing motorsport, it gets fire extinguishers/tool box a few other bits, plus tows a trailer.
I was thinking of swapping out to White/Green/Green (RKB500300)
Spring isolators are fitted and will be replaced with new ones.
Front of the 110 has a winch and winch bumper. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #918750 26th Aug 2021 8:24am
I've made that swap on my USW and it's a huge improvement - the ride is much more pliant. The purple/brown springs are designed with a 1 tonne payload in mind and unless you run anywhere close to that then the white/green/green are a great compromise.
More details here:
https://www.defender2.net/forum/post820610.html#820610 Darren
Post #918751 26th Aug 2021 9:23am
geobloke
Hi John.
I have had both in mine and the difference was noticeable. I also had a similar setup to you in the back with drawers and no seats. Perhaps the RKB500300s were a little more supple on pot holed tracks and whilst off roading, flexing better, but after a while the vehicle sat back on its haunches a little more. Nothing major, just depends on what your preference is with regards to nose down/arse up or a flat centre line. As you can see in LRAs thread he linked to...
I went from the RKB500300s to the RKB101111s as I carry a constant weight in the back with the dog crates and filled drawers. More weight than just the four seats that were in there when I bought it. Since then I have gone to Old Man Emu single rate springs due to the constant load and they work beautifully, although irrelevant to this thread.
Plus... there s a pair one bay at the moment for £50... https://www.ebay.co.uk/itm/174838637959?ha...ition=3000 - make them an offer Thumbs Up
The specs of the two springs are below
RKB101111
D110 heavy duty and D130 (VIN XZ159807 up)
Rear
16.10"
270/420 lb/"
8.8 coils
brown/purple
RKB500300
D110 station wagon (VIN XZ159807 up)
Rear
16.90"
240/280/360 lb/"
9 coils
green/green/white
Post #918752 26th Aug 2021 9:40am
excossack
Thanks both. I think from memory last time I (the 110 not me) weighed in at 2400kg and the trailer 500kg - which does lower the back end a little when hooked up.
LRA - cheers for the link
GeoBloke - also cheers for the link to the springs. 1999 Defender TD5 110
Regards
John M0VAZ
Post #918756 26th Aug 2021 10:21am
