![]() | Home > Puma (Tdci) > Crank position sensor |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4317 ![]() ![]() ![]() |
Also consider looking at Genuine Ford ones, they’ll be the same as LR probably quite a bit less £££. 2007 110 TDCi Station Wagon XS
Genuine if possible, OEM if not and pattern if desperate...
Think I need a t-shirt with that on ![]() |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
I’ve got a spare maf / map which are Ford. Does anyone have a Ford part number?
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
are you collecting spare parts ? |
Retired & driving to SA & beyond..
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
I'd go genuine or OM if you could, although there isn't anything to go wrong with them if I'm honest.
Remember to swap them out you'll need to remove the heatsheild ( not the main turbo one, but a smaller one ) which takes an 8mm socket and is a wee pita to remove...it takes you looking out of the bonnet whilst your hands feel for the bolt ![]() I'm rebuilding my engine at the moment so I'll take a pic for you so you've got a visual of how it sits |
Lucky ![]() ![]() |
Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114 ![]() ![]() ![]() |
I've just rebuilt my engine, (see my full build on my You Tube channel), and my heatshield was just "clipped" on and I cannot for the life of me get it to sit back on without flopping about. Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
