Home > Td5 > Interior light LED bulbs - what size
excossack
The LEDs I removed from the interior lights are 35mm, Ordered some new ones at 35mm and seem a bit slack (the tabs that hold the bulbs are bent in a little to make a better connection but still not perfect.
What is the right size for LEDs? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #917355 17th Aug 2021 8:30am
I'm pretty sure that the originals should be 36 x 10.5mm but the holders can be tweaked to take longer ones up to about 39mm.
These ones offered by Flatdog are 39mm:
https://www.flatdoguk.com/led-interior-festoon-bulb~2518 Darren
Post #917364 17th Aug 2021 9:07am
excossack
Cheers, 39mm seems to be the same as the ones I took out. I think I ordered the wrong ones(35mm)
Time to order some more! 1999 Defender TD5 110
Regards
John M0VAZ
Post #917380 17th Aug 2021 9:50am
