Home > Maintenance & Modifications > Repair shop wanted in Zaragoza Spain
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
We’re on holdiday and it’s becomes a tradition that something is wrong with the car. Big Cry
Therefore we are looking for a repair shop in the neighborhood of zaragoza. We are actually in Caspe which is 130 km from zaragoza.
Kind regards Jack and the family
Ps it’s a whistling sound in the neighborhood of the turbo but I can’t find any soot. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #917302 16th Aug 2021 7:58pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Can't help directly but may be worth a pm to ALBERTDEFENDER he's based in Girona and may know someone.
Good luck Thumbs Up
His videos taken around Catalonia are worth a look. Just because you're offended doesn't mean you're right.
Post #917312 16th Aug 2021 8:35pm
excossack
Have you split an intercooler hose? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #917318 16th Aug 2021 8:42pm
Tdi4
Can check that tomorrow. Didn’t think of that. Looked at the turbo inlet hose today. But that was fine. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #917322 16th Aug 2021 8:51pm
Sulisuli
Self amalgamating tape may help you get to a garage slowly if it’s a hose Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #917323 16th Aug 2021 9:02pm
Tdi4
Of course. It’s standard equipment in the car 👍.
The noise is only when there’s no or very little load. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #917326 16th Aug 2021 9:13pm
ajps72
2001 Defender 110 Td5 SW Chawton White
could it be always but not heard with the engine noise??
can you hear it at idle?
I would think it could be a hose before or after the turbo, that is loose or split, or it could also be a accessory belt pulley Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #917417 17th Aug 2021 3:35pm
Tdi4
In the end the car just stopped before finding a problem. Don't know if it is related or a new problem. The car is still being repatriated to the Netherlands (second time in 3 years). a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #920642 9th Sep 2021 7:42am
