Home > Maintenance & Modifications > power invertor location |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3998 |
If it’s the station wagon with all the seats still in place, I’d probably look at putting under second row seats somehow. Or attached to rear of the cubby if it’s not too large a unit. 2007 110 TDCi Station Wagon XS
15th Aug 2021 7:56pm |
You don't say what variant you have but;
Back of the cubby box. In the drivers side under seat compartment. Mounted on a board and then fixed to the dog guard (if you have one. This is where mine will be) Under the second row seats. Under the cubby box in a Mudstuff or Naka box. Back of the front bulkhead behind the front seats (if an older vehicle. Had mine there in my 1992) To the left or right of the rear door under the 1/4 windows (requires a mount but is usually dead space) As to the routing of cables, there usually some unused grommeted holes in the battery box to the rear that conveniently lead to the top of the chassis rail. From there it is a case of deciding where to bring it back in to the vehicle utilising a waterproof gland. How does that inspire you? |
15th Aug 2021 8:05pm |
