Home > Maintenance & Modifications > Galvanised Door Frames
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
Apart from SP4x4, who makes galvanised door frames (with or without ally skins fitted)? I'm after a set of doors with galv frames but i want to minimise weight and have ally skins - and SP4x4 won't do that. Having spoken to an aircraft engineer i know, i'm happy that duralac will prevent dissimilar metal corrosion. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #916317 10th Aug 2021 11:28am
Linds Hanson
Just fit Puma doors job done
Post #916318 10th Aug 2021 11:32am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Re: Galvanised Door Frames
SP4x4 previously offered both skin options, but presumably the aluminium skins were less popular so have been dropped. I got the zintec version a few years ago and remain very happy with them.
How much weight are you expecting to save by not having the zintec skins? I'd be surprised if it's more than a few lbs.
Post #916322 10th Aug 2021 12:50pm
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Yes, Duralac is a Thumbs Up for keeping corrosion out of joints. Used it on all sub and main assemblies back in the day, regardless of whether they were similar or dissimilar metals.
Still use it now too.
Laurie
90 rebuild thread - https://www.defender2.net/forum/topic62909.html
Post #916360 10th Aug 2021 3:56pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
On a historical note Series One doors from the 54 model year to the end of production in 1958 had the Birmabright skin on a galvanised steel door frame with no sealant between the Birmabright skin and the frame. You never see any corrosion of the Birmabright on these doors.
Post #916371 10th Aug 2021 5:01pm
Gasket
I restore Series land rovers and try to preserve original paint where I can.
To this end, I've previously bought bare steel door top frames from SP4x4, galvanised them myself and fitted the original skins back on.
Post #916376 10th Aug 2021 5:30pm
Birmabright is a lot more resilient than the regular aluminium used on later models and doesn't corrode in the same way. Darren
Post #916420 10th Aug 2021 9:41pm
defender9
^^^ Didn’t Series 2 from 1958 and later 2A have Birmabright door skins? I had a Series 2 many years ago where the door skins had corroded at the bottom.
Post #916440 11th Aug 2021 7:25am
Birmabright was used up to the early eighties when the company went out of business. It wasn't corrosion proof but was much better than what came later. Darren
Post #916445 11th Aug 2021 9:03am
