![]() | Home > Maintenance & Modifications > SEED NETS RADIATOR PROTECTION |
JEFF DEFENDER 90 Member Since: 05 Aug 2021 Location: SURREY Posts: 4 ![]() ![]() ![]() |
ARE SEED NETS WORTH FITTING TO CROSS AFRICA
thanks for the Answer, i fould a guy who fitted one and crossed the Kalahari Desert with one fitted 2000 miles and had no heat problems and it was 44 degress, so i dont think heat will be a issue, so i think thats a road test and a half ??
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
I spent a lot of time in the Kalahari, Namib and the Okavango as part of a Cape Town to Nordkapp trip. I'd fit the seed nets when needed otherwise they're just collecting bugs.
thanks very much, i found a guy in Surrey that sells them,
jddisco200tdi Member Since: 22 Jul 2008 Location: Melbourne, Australia Posts: 21 ![]() ![]() ![]() |
Here in Australia you do need a cover to the radiator for some of our deserts. Grass seeds are the main thing to stop.
Anything like shade cloth does restrict air flow. I use window flyscreen netting, and only install it when I get to the area it is required. Another thing to watch out for is grass collecting above bash plates. It can catch fire quite easily. Regards John D - Defender 110 2.4 |
^^^^ Like the man says...
https://www.club4x4.com.au/4x4s-grass-fire-risks-need-know/ https://blog.tracks4africa.co.za/the-danger-of-long-grass/ ![]() Click image to enlarge ![]() |
Thanks, very useful infomation guys.
