![]() | Home > Maintenance & Modifications > 2.2 TDCI Vacuum pump question |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
I guess depends how much leakage the 2nd connection would create. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3772 ![]() ![]() ![]() |
It’s a relatively small pump, so as Dinnu says, it would depends on what you want to use it for. I’d be surprised if there is any extra capacity, but having said that it might be worth cross referencing with a transit workshop manual to see if they already run 2 systems from it.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
On my 2.4 the pump generates a surprising amount of vacuum (put your thumb over the pipe when it's running
![]() The servo doesn't need a huge vacuum so I would suggest it would run a secondary vacuum provided it doesn't need a huge volume. I'll be interested to hear if it works > 110 XS Double Cab |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268 ![]() ![]() ![]() |
The vacuum pump appears to be used in a few ford power units and in the Ranger 2011-2015 they use both take offs.
I think I will give it a go but check the vacuum on the brake servo side before and after with a vacuum gauge. |
