Home > Maintenance & Modifications > R380 Rebuild Stand |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
Morning All,
Took the extension housing off my R380 to replace the 5th gear with the V8 ratio kit but have decided that I want to take the opportunity to fully strip, clean, inspect and rebuild with new synchros etc. I am sure I have seen somewhere dimensions for a basic rebuild stand (similar to the one which Britanicca Restorations uses in his youtube videos which allows the gearbox to be stripped and assembled vertically. There is nothing I can see in the R380 rebuild manual though. Does anyone happen to have dimensions for a suitable stand at all please? Wont be up at the workshop to measure up the gearbox until the weekend and keen to get some steel ordered to make a stand this week. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
3rd Aug 2021 9:42am |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 348 |
Not sure if this will help. It's a drawing of the front cover where the bell housing bolts onto.
The Lt77 and R380 is apparently the same. |
3rd Aug 2021 4:46pm |
have look at the link
https://1drv.ms/b/s!AtZSoWFHDgnGhUfhpexEdGpupY2Q?e=fNstT2 |
3rd Aug 2021 4:58pm |
Thanks. Hope you don't mind, I downloaded it as I didn't have this particular version.
The shaft lengths might differ but the rest should be okay. Click image to enlarge I will now also make one, just for when I need it. |
3rd Aug 2021 5:20pm |
Brilliant, thanks both. Just what i needed
3rd Aug 2021 5:29pm |
Just to close this off, metal bought and cut to length (marked with lengths for anyone who wants to make one too):
Click image to enlarge All welded up and put to good use. Didnt find any need to put any cutouts in the top for the R380 and have just drilled a single hole for a retaining bolt. I also adjusted the height to make it long enough to accommodate the longer Td5 input shaft variant. Click image to enlarge Click image to enlarge Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
20th Sep 2021 7:49am |
I also made one for a rainy day. As I didn't have measurements of the hight if used on the R380 I made it 250mm.
Luckily my work bench has movable sections if the shaft is longer. |
20th Sep 2021 8:06am |
