![]() | Home > Maintenance & Modifications > Indicators not cancelling/cancelling at wrong time. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3776 ![]() ![]() ![]() |
Have you had the steering wheel off recently?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6012 ![]() ![]() |
Original steering wheel or aftermarket. Aftermarket ones use the sprung collar off the original wheel, or pins in the boss and need to be setup correctly.
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
Make sure the arrow on the indicator unit is pointing towards the stalk when re-installing the steering wheel.
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 242 ![]() ![]() |
Same problem here with the original steering wheel. 03 plate. Defender 90 XS TD5 (03 Reg)
![]() Click image to enlarge Red arrow show indicator causal unit is pointing towards the stalk |
Looks like mine should be fine then?
Unless the ring on the steering wheel itself is off? ![]() Click image to enlarge ![]() Click image to enlarge Defender 90 XS TD5 (03 Reg) |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 196 ![]() ![]() ![]() |
I haven't but might have been off befre I bought it... it's an original wheel. will have a look as suggested. Cheers
