Home > Maintenance & Modifications > How much fluid is needed to flush clutch master cylinder?
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Greetings gentlemen
Im about to replace my clutch master cylinder with a Lof Powermaster and need to know how much dot 4 brake fluid to buy.
I can buy in quantities of 250ml or 1L. Asking because I never want to save brake fluid once opened ... Roaming around 🇳🇴🇨🇭
Post #913169 20th Jul 2021 7:13am
Dinnu
Not on a tdci, but used less than half a bottle of 250ml on an lt77 master/slave. And that was with some accidental waste as the slave piston got pushed out (engine is still out).
PS. I use dot5. That stuff seems to come in 250ml only bottles locally as is damn expensive. Reason for dot5 - if the master leaks, it does not eat the paint off the bulkhead. Something to consider?
https://www.defender2.net/forum/topic78646.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #913189 20th Jul 2021 9:44am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
As a precaution I would avoid using Dot 5, it may not damage your paintwork but is silicone based and can’t be mixed with dot 3,4 or 5.1.
It’s not really intended for road vehicle use. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #913193 20th Jul 2021 9:51am
Dinnu
I do not think the clutch hydraulic is a critical component. But I also do not know why dot3/4 is specified for the clutch fluid. I hear somewhere that manufacturers just specified dot3/4 for the less technical people so that they do not mix up brake and clutch fluid.
How many people wanted to buy the 710 fluid? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #913214 20th Jul 2021 12:44pm
landy andy
I used LOADS. was a Censored too bleed. Had to get reserves in.
Post #913284 20th Jul 2021 7:58pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Just got a lof powerslave delivered. Is it ok to use dot 5.1 in a td5 clutch systemas i already have some in the garage.
Thanks
Post #931404 27th Nov 2021 12:02pm
