![]() | Home > Maintenance & Modifications > Recommend me a paint gun |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
What do you want to spray? Lange body panels, or small parts, like brackets etc?
If it is the latter, no need for anything special. A cheap LPHV gravity feed, 1.4mm tip is more than adequate. The expensive guns usually have a very good fan (the spray pattern is narrow and tall) which gives you good coverage and less likely to run. But for small items, fan size is not that important, actually need less fanning to reduce paint consumption. A £50 gun should already give decent quality. I use a budget gun, mad by SIP, an Italian manufacturer. I get decent results with it. I wish I can justify a Devilbiss though. I also find that results depend in the weather since I do not have a spray booth. Once you get a gun, use water to experiment with the settings. There are a few settings, like paint flow, air flow and fan flow. Edit: I meant HVLP - high volume low pressure, not low pressure high volume ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
Cheers Dinnu. SIP sounds like a good bet.
If you are curious, I have this one. The description says ‘professional’, but I doubt that.
https://www.sip-group.com/store/category/110/product/02138.aspx But then it depends on the hand / skill of who is using it, and the paint that you are using. I got some paints that were less likely to run than others. As a start, do not try water based base coats. Keep in mind that to get a nice finish you need as much as possible paint, but not too much to make it run (for 2K solid paints). That would reduce orange peel. PS.. I am not a professional painter... just learned from my own mistakes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
I bought one one of these with a couple of different nozzles: https://gtair.co.uk/46-spray-guns
Been very happy with it. Done a car door, engine sump and a few smaller items. If all you are doing is smaller items then a touch up type gun might be better. You’ll waste a lot of paint using bigger guns on small parts. Having 2 different nozzle sizes means you can spray thicker paints like primers and chassis paint and thinner stuff like colour coats and laquers. Even the LVLP guns use a lot of air by DIY standards so you need a decent-ish compressor. You can make the most of your compressor by using high flow euro fittings instead of PCL and larger bore hoses. I have a remote regulator and water trap too. It’s worth spending time messing around with the pressure to find where the gun sprays best and also how much to thin the paint. 2007 110 TDCi Station Wagon XS |
I also sprayed my kitchen radiators with came out brilliantly. 2007 110 TDCi Station Wagon XS
Thanks everyone.
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878 ![]() ![]() ![]() |
I've had my Devilbiss FLG-5 for 6 years now, purchased it second hand from eBay and have painted an entire 110, numerous components and wheels etc. I would thoroughly recommend it.
Other things to consider: A good respirator Water trap Inlet pressure gauge 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I have a pair of Fast Mover (actually a UK company despite the Chinese sounding name) LVLP guns in both 1.3mm and 1.8mm. They still use a surprising amount of air so be aware that your compressor may well struggle.
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
