![]() | Home > Puma (Tdci) > Leaking clutch fluid |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3679 ![]() ![]() ![]() |
if its the master cylinder you generally get fluid in the front foot well. DEFENDER 90 TDCI XS,
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2362 ![]() ![]() ![]() |
Get underneath the vehicle, is there moisture/evidence of fluid coming out the bottom of the gearbox bell housing? > 110 XS Double Cab
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3630 ![]() ![]() ![]() |
Unless it is going under the carpet!! In that case, keep in mind that dot4 will eat the paint. No paint = rust. If the slave is leaking, then it is a box out on a tdci. I still do not understand why clutch hydraulic is specified as dot4. I hope that neither the master nor the slave reach 100dC or so. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2304 ![]() ![]() ![]() |
It simply most common these days, can't recall the last time I saw dot3......
Indeed, makes more sense to use dot4 than dot3... but both eat paint, in case there is a leak of course.
Hence for my restoration I went for dot5 (silicone based and not to confuse with dot5.1). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Sorry to thread jack, but while we are on the subject: I’m going to replace my perfectly heathy standard clutch master cylinder with a lof power master this week
What’s the best way to drain enough fluid that I don’t make a huge mess in the engine bay, yet also not introduce too much air as to make bleeding of the new master difficult? ProTips appreciated in advance 🙏🏼 Roaming around 🇳🇴🇨🇭 |
I think better to drain the fluid from the bleed nipple. Even if there is a small amount of air in the system, you will need to bleed it completely. The positive thing is that you have new fluid all the way. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
