Home > General & Technical (L663) > Air suspension sensor fail - can you drive?
Page 2 of 2 <12
SteveG
2005 Defender 90 Td5 CSW Belize Green
With some length of pipe, pipe cutter and fittings, you could cut air line to spring/s splice in a fitting and then manually inflate bag/s to desired height. Then see how system reacts to it.
This could all be done before you go to test it out, and you could even plumb in a manual override near the valve block/s prior to leaving if everything works ok.
Post #912903 18th Jul 2021 11:53am
J77
Or just go with the coils, unless you really need the extra height.
4 months I’ve had mine, no regrets not taking the air suspension. 24MY 90 D250 HSE, Tasman Blue
Post #912928 18th Jul 2021 3:09pm
zilch
Australia
Use to be able to get emergency air up kit for the RRS, carried a set for our off road trips, pump up
with your tyre compressor and hey presto, be interested to see if a similar system becomes available
for the Defender. Some EAS could be permanently fitted.. yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #913006 19th Jul 2021 8:23am
G&T
One call with a LR dealership suggested that if I’m keeping the vehicle for longer than 12 years then coils would be a ‘good option’. Very Happy
Post #913016 19th Jul 2021 9:29am
4B4B
The same could be said of any option that adds further complexity to a vehicle.
I’d just go for what was needed for my application. If the extra height adjustment flexibility and comfort are things that you’ll think you will benefit from. Consider it. But if not, the coils feel great apparently too, just opt for those, and save the £1600 upfront expense, and the potential extra maintenance down the road.
See if you can test drive both types. [/quote] Disco 4 Owner
Post #913031 19th Jul 2021 10:28am
G&T
4B4B, to test drive both for me is a must. I’m very interested to see the difference and is it worth the extra.
I know how the extra complexity can play with your mind - when away away Smile
Glenn
Post #913044 19th Jul 2021 11:45am
Page 2 of 2 <12
