![]() | Home > Puma (Tdci) > Central locking 2nd row |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
Interesting notion of a "fix" - putting in a wire that's as inappropriate as the original one...
![]() There are high flex wires used for measurement leads, for example. Or cables like Lapp Ölflex. Personally, I would use crimped shrinks wrap connectors. |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Quite! You’d have thought Landrover would have replaced the loom but no….like everything else they touched on the 110 repaired at the minimum price point!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
All mine are now replaced with high flex wire and I've rerouted the second row door rubber sleeve to avoid the very sharp bend the halfwits at LR introduced. If you compare front and second row doors you'll immediately see why the second row fails more than the front.
I bet that the Grenadier never has this problem. |
